Hello all,
I have an issue with the truck and looking for a little input. I am seeing Map senor voltage to high code with the smarty, but no check engine light. The truck runs fine until you lay into the throttle. If you are on it runs fine until about 35lbs of boost then falls on it face (5-6 lbs of boost) smoking like a freight train. If you ease into it the boost climbs 35-38 and will stay there until you let off the throttle.
My question would what should I check? My thoughts are map sensor, comp box, or waste gate. Any input is appreciated.
Thanks,
Thanks,
