Details here: TDR Privileges
It is located on the intake manifold toward the rear and I believe on the side but I could be wrong. There is also the Intake air tempature sensor on the intake manifold.
Try the 3rd gen 5. 9 L forum under facs and questions they mite have a diagram there.
I just looked and all I saw was a 2 wire plug that goes to a cylinder type sensor mounted on the turbo (intake side) and the air temp sensor. Just to make sure I checked the intake horn area also but nothing there.
The MAP and IAT are both located on the left (driver side) of the engine towards the firewall. If you point a flash light at the engine and hold the flash light under you master cyclinder, you will see them.
