Engine/Transmission (1998.5 - 2002) Map Sensor Plug Help??
Engine/Transmission (1998.5 - 2002) P Code 1682
2nd Gen Non-Engine/Transmission Death Wooble
Ok as I sit here and eat old left over Mexican I thought I would try this and see if it would work. I Got a Juice and Attitude off of a 02 Cummins and I want to put it on a 99 but as it is now I talked to a Edge Dealer today and he said the made no adapters for the 99 Map sensonr plug so I just got an IDEA!! If I knew what wires I had to splice into the original map wires on the 99 I would do it!! The wires on the Juice are as follows. . The female end of the 02 juice wiring has 3 wires and the colors are Brown,Black,Black. . The other plug has wires that are Black,Green,Black. . I have no idea what is on the truck it is dark outside and flashlight batteries are dead. . Then all I have to do is select the 99 in the options list of the Juice for the right Ohm settings YEE HAA. . Will it work or not?? So if anyone knows what wires go where that would be worth a nice COLD BEER or COLA on me of course. . Thanks For the Help. . 573 202 9999
If you attempt this I would figure the pin out for both of the adaptors and just match, ground to ground, constant to constant and signal to signal. I just converted a 98. 5-2000 harness to a 2001 harness for my edge comp and everything works just fine. make sure to solder your connection points and use shrink wrap, and then tape the wires together with electrical tape. Dont go off of colors, find you some pinouts on line. I googled them and came up with them and was fine. There are three wires, One ground, one Constant 12v and one signal wire that signals up to 5 volts. Also cut only one wire at a time and then solder it. Then cut your next wire and solder it, etc...
