Engine/Transmission (1998.5 - 2002) MAP Sensor Question
Engine/Transmission (1998.5 - 2002) Gauges
Engine/Transmission (1998.5 - 2002) ECM to LP circuit questions
I am experimenting with an idea I had a while back and I need to know which wire on my 02 MAP sensor sends the voltage reading to the computer.
Thanks guys, CJ
looks like Grey/Red according to the FSM Pdf's. Pin 27 on the PCM
on edit: lets see if i can paste these in here
MANIFOLD ABSOLUTE PRESSURE SENSOR (DIESEL) - 3 WAY
CAV CIRCUIT FUNCTION
A K7 18OR 5V SUPPLY
B K104 18BK/LB SENSOR GROUND
C G12 18GY/RD MANIFOLD ABSOLUTE PRESSURE SENSOR SIGNAL
looking at the plug with the retaining clip facing DOWN pin A is to the left, B in the middle and C far right. Pin C is the one you want.
