ok got a question for all the cummins techs out there, or anyone in general who has played around with a scanner on our trucks. Put the Snap On scanner on my truck this evening to clear some codes and what not. i noticed that at idle. the voltage is 1. 1. Here is the wierd thing, according to the scanner, that is 15 psi of boost. when driving, i saw as high as 2. 4 volts, and 34 psi, but why in the heck is the thing not setting overboost codes, and defueling?? It was strange, because the boost reading on the scanner and on my boost gauge were proportionally 15 psi off (ie my boost gauge said 0, scanner 15, my gauge 5 scanner 20 etc etc. ) all the way up to my gauge showing 19 psi, scanner showing 34, then the scanner quit increasing, even though i ran the boost all the way up to 39 psi on my spa. i assume this is due to the boost module in the ez doing its job. so is it just the values are off on my scanner or what??, i am assuming this is the case, as i even unhooked the ez thinking this may have something to do with it, results same. (didn't drive it to see if values kept going above max) Hoping to hear from some of the guys with a snap on scanner to see if you have had similar results. thanks
