Competition Marine gasket
Competition How is the GT42 as a single?
Competition Got caught racing
When installing a 12V marine gasket on a 24V head what mods are required to the marine gasket. I have the gasket on the block and it appears everything lines up.
Thanks in advance
Malcolm
Thanks, I did notice that the water holes did appear to be a bit on the small side. I should have kept the old 24V gasket to compair.
So just get a hole punch and open them up a bit?
Thanks for the tip
Malcolm
Be careful when punching the holes... . I have seen several gasket failures from guys that "just punched them out".
Doug
Thanks Doug typo mistake!
Felpro #s if you go that way,
02-98 9522PT . o61
98-97 9313PT . 061
96-88 9332PT . o61
96-94 9534PT . 071 (. 25mm)
96-94 9523PT . 081 (. 50mm)
I don't know if it is necessary to punch out the holes, but the holes along the exhaust side on the main surface of the head won't seal in some cases because the 12V gasket has those steel ribs aloong there. You can bore them out and hammer in cup plugs.
