The reason to use the 215 bowl in a 12 valve build is compression. you can't get any valve to piston clearance and over about 15. 7 compression with the 370 marine bowl in the 12 valve, and that is low enough for a trail of white smoke at every cold start. I found the 215 bowl with the thick 3283339 head gasket at 16. 4 compression was better on the street. Now in a 24 valve engine, you need a centered bowl, so neither of the above psitons (215, 370) is appropriate.
