The nut is 30 mm = 1. 181" vs. 1-3/16" which is 1. 187" so I'd much prefer the metric socket since you have to buy one anyway. I have experienced some of those nuts being so tight I use a 1/2" drive long ratchet with a 3' cheater pipe on it. DON'T torque over about 140 ft lb. The threads strip on the pump shaft at about 175 ft lb, and that gets real expensive.
It's an experience doing a pump for the first time. I sent some tips by PM, and hope they help. If you are an rpm hog, you might tighten the gov springs one click as it is easier before installation. The pump is supposed to go to 3000 stock, and stock is how Scott set it.
Again, after installation and tightening the 30 mm nut, pour about 3/4 qt. of oil into the governor housing (remove the afc plug with 5/16" or 8 mm allen wrench. The oil will go in only very slowly through the star wheel hole. Don't forget to remove the timing blade from the side of the pump and turn it around so the pump can rotate.
This is a very rare pump, one that is never sold by Bosch on yearly special at lower price. Since it was used on the highest hp B engine, I wanted to check it out, and jumped on the chance to buy one. I wanted to see what was different about it, but ended up not using it or anything from it. I felt a boater would want it stock and I might get rich selling it to him
Oh, well, I found a starving student instead, but maybe his truck will run better with it, just skim over the waves, errrr, the pavement
Meanwhile, poor old Sickly is limping along arthritically on worn out parts
Next year I gotta buy something good for him and find the [censored] hp level
