I have a 98. 5 24 valve, 5 speed 3500 dually. I love this truck but is has been letting me down lately. Lift pump and VP went out at 225,xxx miles, now truck has 241,xxx on it and i have the dead pedal, no power intermittently issue going on. Truck was at cummins for a week, they charged me $260 and told me they have no idea what is wrong. They want me to start throwing expensive parts at it as a guess, starting with the cummins ecm at $1200, but they are not sure it will fix it. Seems something is randomly telling the lift pump to drop pressure to 4-7 psi like in start mode, then it goes back up to 12-14 psi after anywhere from a few seconds to several minutes. No check engine light but it does show pump timing failure codes. Both the Dodge computer and the Cummins computer seem to be cycling codes back and forth to each other. I have purchased a map sensor as an inexpensive and probably futile guess.
The truck has upgrades, makes pretty big power-edge box, 300 hp injectors, afe intake, banks turbo, banks 4 inch exhaust, banks exhaust brake, US gear overdrive splitter, 3. 54 diff.
The cummins people are basically clueless. They said it could be the cummins ecm, the dodge ecm, the VP or lift pump, the ignition switch, any of the various connections etc. basically no help to me whatsoever.
I have changed lift pumps out every 20k miles or less, fuel filters at least twice before the lift pumps. engine is in no way tired and burns no significant oil.
I need my truck to be dead-nuts reliable, i use it for numerous cross country trip every year hauling collector cars. Buying a new truck is out of my wallet range(the cummins people actually suggested this as a fix!) i dont have a spare 50 large sitting around. I am losing hope as to spending thousands more on this rig for it to possibly fail again soon!
Does someone make a badass VP that makes power and wont be so freakin delicate? should i install two F. A. S. S systems in it, one for active use and one for redundancy? Should i sell it as is and look for a 94-97 12 valver or a 02-04 new gen for a very hard to find resonable cost? Are the new gens any more reliable and can i make the same or more power than my truck easily? I drove a new HP 6 speed truck recently and it was a gutless wonder compared to my workhorse so i am concerned, one does get spoiled by Horsepower!
This is my problem and i am kinda freaking out about it!
Any help or advice with this dilemma would be helpfull!
Thanks, Lee in San Diego
