From reading the threads I picked up on this great device that pressurizes the lubrication system befor start up. Its just a simple
neumatic tank. You fill this cylinder with engine oil and presurize it with air. A switch is mounted on the dash that is used to activate a solonoid. The oil is pushed out of the cylinder and presurizes the engine. A built in safety valve prevents air from entering the engine if the cylinder went empty. When the engine starts the cylinder is pumped back up from oil pressure. Its ready for the next cold start. Check out this web site. www.masterlube.net or contact -- email address removed --
