It's HOT here in Phoenix these days so I've been using the AC more than usual. My normal routine when getting in a hot truck is to crack the windows and put the AC on "normal" until the cab is about the same temp as outside. Then I roll up the windows and switch to "Max" (re-circulate).
The last couple days I've noticed that when I switch to "Max" the fan makes more noise (as usual) but the air volume coming out of the vents actually goes down (used to go up). It's like I switched it to bi-level or something. I've checked the defroster and floor vents but there's not much air coming out of there so where's all my air flow going?
Any ideas on this one?
Any help would be most appreciated. Did I mention it's HOT here?
1999 24V, NV4500HD, QC, 4x4, 3. 54, 8' Bed w/ Rhino Lining, 285/75R16s on 16x8 Eagles, Glasstite high topper
