Max boost with Edge elbow on a 03 HO ?
Fan overspeed?
diagnostic code
I was seeing 22-24lb max.
After elbow install, I'm seeing about 32lb max at WOT.
Is this about normal? I don't want to damage the turbo.
P. S. These reading are on analog gauges.
Leave the stock elbow in!
Ideally, you should have a 1:1 ratio between boost pressure and drive pressure.
Measure your drive pressure at 32 psi boost... :eek:
Anything more than about 25 psi on the HY35 is too much. More boost does not mean more power.
I know it sounds like the turbo is working harder. I have a stock air box and it pulls the filter monitor half way down.
I was ideally wanting about 26-27lb boost. I guess I will leave it stock or buy an adjustable elbow.
I run my EZ on level 4 and sometimes level 6 and see cooler EGT's without the elbow. You reach a point of shoving hot air in and get hotter air out.
