Max Tire Size
Cheap Winter Front
Want to sound deaden your truck? I have some advice...
I run a 315/70r17 Mickey Thompson MTZ on stock rims. I ran them before I leveled the front. They fit fine, only rub slightly on the lower trailing arm on a full turn. Different tires in that size may not rub at all. There is plenty of discussion on this subject if you search the forum. Hope this helps
Mike
I ran for a few years w/o a lift since I have a leveling kit on front just to lvl tires was fine w/o though
If you look under my pics, you'll see a gray '07 Regular cab 2500 with 325/70/17s on it. They only rub on full turn lock, with no lift. I have several of these trucks, and don't run a lift on any of them, but my 3500, which only has a leveling kit, compliments of the previous owner.
