Well, I spent some time trying to install my new MaxBrake. Came across a couple of things I wanted to share. I will apologize in advance for a long post, but I need to vent.
1. - The control unit is huge! At least compared to my Tekonsha Prodigy. Now I know the Prodigy is not the best brake controller on the market but it sure did mount nice. I have everything torn apart to allow mounting the new control head which has required other items to be removed or miniturized. Again, not the end of the world but worth mentioning for others who have yet to do the install. Its size does limit options, especially if there's other "stuff" already mounted in your cab.
2. - The power/brake pedal harness is identical, at least for my application. I verified the pinout and was able to plug the harness from the Prodigy directly into the Maxbrake. Please double check yours, lest you let some smoke out of something expensive!
3. - Putting the "tee" in the brake line was real easy. I used the 8" line supplied in the kit to mount the sensor for now. Since my branch on the "Tee" is pointing straight down, I plan on shortening that up a bit later on. I just don't have access to large fitting supply places right now.
4. - The sensor cable. The cable included in the kit has two different ends, an "A" and a "B" that will both plug into the sensor. The instructions clearly state that "B" is only to be used for factory testing. OK, fine, but why create a situation where someone may plug in the wrong one? If its for factory testing only, why do I need it? What happens when that other end gets covered in mud or water in my engine bay? Will the exposed pins short and do any damage to the control unit?
And now for the bit that prompted the name of this thread. Once I knew the power harness was compatable, I plugged it in. Unit lit up and after a few seconds gave me a couple of warnings, something about checking the sensor and checking the trailer wiring. Both are reasonable considering the sensor cable was not run at the time and I do not have a trailer plugged in. So far so good. I unplugged the unit and put it aside while I ran the sensor cable. Problem is when I plug in the sensor cable. Based on #4 above, I triple checked and verified that I had the "A" end plugged into the sensor. Then I plugged the 8-pin jack into the control unit, and finally, the power harness. Flipped the unit over and ... ... ... . nothing.
The screen is blank, no backlight, nothing. As soon as I unplug the sensor cable it seems to fire right up. If I plug in the sensor cable now, the screen goes blank again. Pull sensor cable out and it goes through the startup routine from the start. Disconnected the actual sensor, same result. Ignition on or off, same result. Leads me to believe I have a bad cable. We'll see what the MaxBrake people have to say in the morning.
