Hi
I was just out on a test drive after changing my VP and noticed my LP psi was up and down. Up at cruising speed is about 12-13 and down @ cruising speed is 5-6. I went back to my garage and did the bump the starter LP test. the pump ran @ 15psi then sounded like it was cavitating and the psi dropped to 5-6 just like on the road. Do LPs do that when they go bad or should I check for plugged fuel lines or air leaks or something?
Mike W.
palmer, Ak
Mike W.
palmer, Ak
