MBRP installed today...freakin' wicked.
TSB question.
1000.00 Dollars for 4-TOYO 33x12.50x18 Used?
Well the UPS guy shows up around noon and just had to slap it on. Start to finish including test drive was around 2. 0 hrs, beer breaks included and 30 minutes wasted on a minor glitch :D . Since I had air with an impact and die grinder it went fairly quick.
The sound... ... ? I can only describe it like this... If Porsche built a turbo diesel of this displacement, it would likely sound like a Cummins HO ISD with a MBRP. At cruise I couldn't tell the difference from stock... just as quiet, no drone or resonance. I haven't had it on the hwy doing 70 yet so I may refine that statement later. Only when you get into it does it growl. Almost like the sound of a kitten purring... well... er... a 7000 lb kitten that's very very angry. :eek: It seems to have picked up a little more grunt but we'll see when I throw it on the dyno in a few weeks after the intake mods.
Quality and fit was what I'd expect for something this size. The T-304 looks like T-304 should. The design of the can, as most of you have seen on DPP's site, is unique. All hangars lined up well and there's enough adjustability to situate the tip either high or low depending on your taste. I tucked it up close to the fender and will post pics later. The tip is nicely done with a mirror polish and looks like a bazooka sticking out the back.
Some tips:
1. Silicone the hangar grommets, they'll slip off easier. Remove all of them first except the tailpipe end... do that one last. The shipment box is exactly the right height to set under the pipes to hold them up while you work it off.
2. If you're installing on a DRW/LWB 3500, the extension pipe that comes with the kit is not needed. I wasted 1/2 hour removing the factory extension from the muffler to mount it back on the cat. Just leave the factory extension in place since it has hangars mounted to it.
3. The entire factory exhaust intact, and only separated at the cat, will come out easily without cutting it up.
4. Have enough beer to complete the job :-laf
5. It is a 1-man job but 2 would have made it easier.
Overall, nice setup and killer sound. Time to go scare some old ladies :-laf
Let us know how it sounds on the highway. I am especially wondering about in cab noise (all the time) and if you get any droning at all. thanks
I just got back from another run. Mostly between 40-60 due to traffic. It really sounds stock cruising at 60, maybe even a little smoother. I would have thought it would have been louder. Only when you hit it does it sing.
As a side note... I fired the truck up after I dropped the stocker to see what an open cat sounded like... it was nowhere near as loud as I thought, which leads me to believe that the cat is more restrictive than folks are saying.
I see you left your cat intact, once you remove it and or replace it with something or straight pipe your exhaust will get louder. Its amazing how quiet these exhaust get when your between 60 and 70 mph, 70 to 80 mph it will wake up and then 80 to 90 it will get quiet again. Unfortunatly I like the sound but when towing my rig under load its alittle louder then anticipated, I think Im just getting old, I think its me.
No CAT in CA??? I thought they torchered folks for that in California?? Now in TX that's a different story... the louder the better.
red-rider said:
I see you left your cat intact, once you remove it and or replace it with something or straight pipe your exhaust will get louder. .
I hear ya. This system, cat intact, is perfect for those looking for an exhaust that's NOT obnoxious. While my cat is definately getting scrapped... this system sounds great cat'd, for those looking for "just a little more sack" , without freakin out the natives:-laf
BLACK PEARL said:
Did you get duels or single?
Single. I don't like duals exiting the rear at an angle. My preferance for duals is straight out the back with 2 big gunZ. I've always wanted twin 4" cannons exiting through an old shcool drop bumper. My Z has a set of Borlas that are downright evil.
I may go to duals on the Ram but if I do, I'm going with stacks or through-bumper cans.
Ca? Who? What? Where?
This is Fl. , but when I get done, Ca will be in France where it belongs :D
What muffler did you put in, or none? I have their duals, sound is awesome, but not obnoxious, until you crank up the fueling and get into it hard. Strikes fear into the Flowerstrokers, and DirtyMaxes. Sounds real good bouncing off of them. I have the DPP muffler and it got louder a little bit, as it filled up with soot. Still not obnoxious. I ran mine with the entire exhaust off, just to see what it sounded like, but was surprised it wasn't much louder than with the system on. The turbo cuts a lot of sound out, apparently. I run mine out the sides, like the stock location with a pair of 5" tips.
