McLeod is in, I like it!
Turbo boost tubing??? Suggestions?
2WD-Lo Switch?
The Cummins stud of Glen Avon, Jim Leonard, installed the last group purchase McLeod on Saturday. #ad
Does that say enough?
I was skeptical, with the talk of clatter & other stuff, but nada. #ad
There is no noise in neutral & the clutch pressure is less than stock. There are no vibrations & you can't tell there is a different clutch in there. I tried the 'slipping' reverse & takeoff, just like the wife would all the time #ad
, & it's just like normal. Robin drove part of the way home today & other than use the clutch like a girl #ad
all was normal.
I haven't pushed it yet, still making sure all is broken in. We traveled from So. Cal over to the coast & Hwy 101 & up to San Simeon, then back to Reno today, Sunday. Lots of hwy driving, so not a lot of shifting to break it in, if that's what it takes.
By the way, Jim L is a great guy. If you get a chance, meet the man & have Jim work on your rig. By the way, Jims place is real easy to get to & there is a motel, called the Circle Inn Motel, 909-360-1132, just up the street. Real nice place with a pool & hot tub & they'll let you stay past check out time. The Mgr knows Jim & a lot of fellow Cummins nutziods stay there. #ad
Money Sink - 96, 5 speed, HX40-16, TST #11/280 slid 3/4 way, 300 HP Injectors, Scourge BD Governor kit, McLeod.
4" CATless turn down straight out back.
ISSPRO Pillar, Delvac 1 & Amsiol, RE-0880, Mag-Hytec, 3:54, 235s on Alcoas, Rancho 9000's, Valentine One.
#11 plate days are numbered, custom grind on the way.
Dutchmen 27' 5th Wheel.
GoldWing.
Forrest,
Congrats! Its and great clutch and you are sure right about Jim, he is the best. Dangerous, I only live 25 minutes from him #ad
[This message has been edited by Mike Vonada (edited 01-08-2001). ]
