MacGreenie
1998 24v Ram 2500. 67K miles.
Should I go with mechanical or electrical on oil pressure guage installation? I plan to tap into the top of the oil filter mount into the 1/8 NPT plug that is currently there.
I am concerned that the instrument cluster oil pressure guage is not very accurate.
I do not know what the high limit of the engine oil pressure output is... over 100 psi, I imagine, so I think a good quality guage is in order.
I have toyed with the idea of a mechanical guage but do not like the nylon tubing or even copper tubing (1/8th inch) that comes with auto parts store versions because they look flimsy and susceptible to vibration or heat damage.
Where to go to get good braided hose (that is long enough) for a mechanical guage? I do not want high pressure oil running to the cab without an assurance it will stay in the guage! Any kits out there with braided "sender" lines? Anybody enginneer something really spiffy and want to show off the photos.
Also, I am running out of space thru the firewall hole to run more wires. Currently wired for oil temp, oil press, boost, rear diff, egt, transmission, water temp and dual fuel press. All Westach guages except do not have an oil press guage yet. Doubled some up with switches. Thoughts on alternate firewall passages?
Thanks everybody... keep on dieseling!
