MegaFlow Exhaust(sp?)
What is this obove fender liner on 04.5
Disabling the seatbelt chime...
Sounds like a big rip off. I bet it is not even stainless either.
Go with a bolt on kit like MBRP.....
Its less and stainless and easy to install yourself
good luck
Erik
Magnaflow does have some aluminized products. I have one of their 24" mufflers on my '03. If you live in as area where they don't salt the roads in the winter then, I think the aluminized systems live fo a long time. I have a Banks aluminized system on my '91 that has to have been on for 10 years, now. It still looks good. And I check it every oil change. Hope this helps. Joe F. (Buffalo).
good luck
Erik
It is staiinless and comes with the chrome tips. Not sure if it is all 4", but it must be. I wansn't aware that the aluinized was available in the duals from this vendor? thanks, Doc
You might look at a Aeroturbine, sounds great and alot cheaper. Check out the website, it has sound files o you can get an idea of the sound it produces. Dropped my EGT 50 to 100 degrees. Oo.
