Memorizing formulas
750x20 impliment tires
Go Wings!
Is there an easy way to memorize formulas?
I'm taking a test to upgrade my license, and I need to remember about 60 different formulas. Cant take notes or a calculator with me.
I need HELP!!!:D
Eric
The best way to memorize a formula? Know/understand how to derive the formula - you'll never have to worry about remembering it again. Sounds painful because it is.....
Brian
I was afraid that would be the answer. :(
My little brother went to college to become a mechanical engineer, and in the 4 years he was there, he told me that he NEVER had to remember a formula. :rolleyes:
God, I sure hope I pass, math wasnt my strong point. :D
Eric
I always used them alot to memorize them. Make up your own problems to use the formulas on. Worked for me.
BTW, ask your little brother how he made it through thermodynamics, heat transfer and physics without formula memorization. We had to memorize the entire thermodynamic continuity equation in thermo class. I would have to look it up in a book now, too many beers since my school days. :D :D
One good quote from a mechanical dynamics prof. "The only equation you need to know is F=ma, everything else can be derived from that. " I never liked that guy. :mad:
Try to use acronyms to help with some things
BRASS= Breath, Relax, Aim, Sight, and Squeeze
One I use for resistor colors:
Bad Boys Rape Our Young Girls But Violet Gives Willingly:
B=black
B=brown
R= red
O=orange
Y= yellow
G=green
B=blue
V= purple or violet
G= gray or slate
W= white
Don~
Guess that's what colleges now are thinking. Hell, I have to write myself a note to remember to buy a loaf of bread and eggs on the way home from work. :D
You must have graduated a while ago. He graduated a year or two back.
It was a repuitable college in Colorado too.
I dont know why I should even have to know this. I'm only an operator, not a design engineer. :confused:
Overkill to say the least.
Eric
B=black
B=brown
R= red
O=orange
Y= yellow
G=green
B=blue
V= purple or violet
G= gray or slate
W= white
Don~
Good ones... When learning to fly I used acronyms and "sayings" to learn things too...
RGLR (Regular) = Right Green, Left Red for marker lights on the wings
ANDS = Accelerate North, Decelerate South, referring to magnetic compass errors while changing speed
Odd People Fly East = referring to air traffic and what flight level to expect them at. East bound air traffic usually fly at odd numbered flight levels
The list goes on... As far as FORMULA's, I too was always allowed to carry either a "formula book" or something similar to college exams. Sorry dude.
Duane
Originally posted by NVR FNSH
what formulas are you using? Just curious
Brian
Well lets see, I dont know where to start.
How to find the frequency of a turbine generator,
Celcius to farenheit, and vise versa. (that one's easy)
Specific heat
Rated boiler HP, and developed boiler HP (another easy one)
Factor of evaporation(which will be used in the DBHP formula above)
Lots of stuff with fuel BTU's, and API.
Heating surface formulas (easy)
Max allowable working (MAWP) and bursting pressures
determining the dia of a piston in a pump
Determining the thickness of a drum
Determining the thickness of a tube
Heating surface
GPM formula
Total head formula (this aint a joke)
Formula used to determine the gallons of cooling water required to condense a given quantidy of steam in a steam surface condenser. ??
They'll give you a question that will require several formulas to answer.
I've just scratched the surface here.
Eric
The flashcard thing worked best for me. Take some time and write them out yourself. Don't get help with them. The time of writing them is more repetition for your brain and uses a different part of it as well.
Also, learn it both ways. Look at the formula and say what it is. Look at the problem and state the formula.
If you do the accronyms, silly is sometimes good. They tend to stick with you as long as they are not complicated.
Good luck,
Scott
Eric, sounds like you're taking a boiler operator's test. I did one last year, study book was full of formulas, test had none.
Yup, but this test WILL have these formulas. :(
I can handle all the questions pretaining to operation (I've had a license for 20 years now) and even the questions on laws, rules and regulations and ASME/codes stuff, but this math is a killer for me.
Eric
Sorry to say, it really comes down to how much time you spend going over & over them until theyre planted like multiplication tables.
But that time spent to remember them will pay off sooner or later, when you dont need to pull out the book to look em up when you need them in a bind.
"Sum of the squares"
A couple more:
For EIGRP:
Bob Dylan Really Likes Music
Bandwidth Delay Reliability Loading MTU
The IOS Layers:
All People Seem To Need Data Processing
Application, Presentation, Session, Transport, Network, Datalink, Physical
RoyGBiv
Red Orange Yellow Green Blue Indigo Violet
PIE TURD
P=IE I=E/R Pi=2R*3. 14... Pi=d3. 14
Good Luck! I have two more years till I have to re-take my test for Grade I Steam Engineer for Seattle to remain current.
I have been out of the power generation end of things for a while.
