MALE VS. FEMALE AT THE ATM MACHINE
A new sign in the Bank Lobby reads:
"Please note that this Bank is installing new
Drive-through ATM machines enabling customers to withdraw cash without leaving their vehicles.
Customers using this new facility are requested to
use the procedures outlined below when accessing their accounts.
After months of careful research, MALE & FEMALE
Procedures have been developed. Please follow the Appropriate steps for your gender. "
MALE PROCEDURE:
1. Drive up to the cash machine.
2. Put down your car window.
3. Insert card into machine and enter PIN.
4. Enter amount of cash required and withdraw.
5. Retrieve card, cash and receipt.
6. Put window up.
7. Drive off.
FEMALE PROCEDURE:
Unfortunately, most of this part is the Truth. !!!!
1. Drive up to cash machine.
2. Reverse and back up the required amount to align
car window with the machine.
3. Set parking brake, put the window down.
4. Find handbag, remove all contents on to passenger
seat to locate card.
5. Tell person on ce l l phone you will call them
back and hang up.
6. Attempt to insert card into machine.
7. Open car door to allow easier access to machine
due to its excessive distance from the car.
8. Insert card.
9. Re-insert card the right way.
10. Dig through handbag to find diary with your PIN
written on the inside back page.
11. Enter PIN.
12. Press cancel and re-enter correct PIN.
13. Enter amount of cash required.
14. Check makeup in rear view mirror.
15. Retrieve cash and receipt.
16. Empty handbag again to locate wallet and place
cash inside.
17. Write debit amount in check register and place
receipt in back of checkbook.
18. Re-check makeup.
19. Drive forward 2 f e et .
20. Reverse back to cash machine.
21. Retrieve card.
22. Re-empty hand bag, locate card holder, and place card into the slot provided!
23. Give dirty look to irate male driver waiting
behind you.
24. Restart stalled engine and pull off.
25. Redial person on cell phone.
26. Drive for 2 to 3 miles.
27. Release Parking Brake.
MALE PROCEDURE:
6. Put window up.
7. Drive off.
FEMALE PROCEDURE:
back and hang up.
8. Insert card.
11. Enter PIN.
cash inside.
21. Retrieve card.
behind you.
