Metal piston cooling nozzles
Why turn an Edge EZ box down?
They have cooling nozzles. I presume they are metal. I don't see plastic standing up for long in that environment.
Casey
The piston cooling/lubricating J-jets can bea combination of plastic and metal or completely metal.
Traditional piston saddle jets (piston coolling nozzles) are plastic and are still used in some industrial applications.
--Justin
all have had cooling jets. the older ones had saddle type jets, the newer ones have "j" shaped jets that point the oil directly up inside the pistons
04. 5 have plastic jet with banjo bolt, prior models have metal jet with fluted bolt and are not interchangable.
