wondered what that little spot on the ground was and saw a nice red fluid on the line... what the heck? onto the creeper to play around thinking that the ATF was leaking from the fittings. lifted the top one and got sprayed (mind you i purposely had it in neutral).
either a plastic insert was missing or the one down there was too far to one side... . over time the pressure line to the oil cooler rubbed on the one below it causing a hole... .
just something to check while you're out (i've heard of the lines running against something else before
Tom
Tom
