With the set up you have, there is a good possibility of heavy tongue weight. I would run the rear at 75 pounds pressure and the front at about 60 PSI. Do you use a load leveler type hitch? If so and you transfer weight forward, I would run the fronts at 70 PSI. This is based on th tires having a max pressure rating of 80 PSI.
When I'm not towing, I run the front at about 50 and the rear at 60 PSI. Makes the ride a little softer. The tire shop also agrees with this and asked if I tow or not.
