I knew things were going too smoothly for way too long. Sometime around 900 miles from home on my almost bi-annual trip to the Fla Keys in the middle of No where I95 south I got that dreaded chime and MIL check engine lamp
. With out my scan tool an no dealer in sight and nothing showing out of the normal, except for lower than normal MPG"s we kept on going. Get to the Keys the lamp goes out. After a week an a half and one crushed cab corner:{, Trees do not like this truck as one fell on the hood last summer and this one in Key West jumped into the path of my cab
. But that's another story. The body shop will be preforming surgery on the roof late next week.....
On the trip home around the same middle of No where I95 I get the same chime and MIL lamp
Get home and see Mr. dealer and the following codes show up;
P1475 intake air diverter valve out of calibretion/ missing calibretion, P249E Closed loop reductant injection controll flow too high, B22A900 ECU internal performance issue.
First thing the dealer starts sayin is what DEF fluid are you using? Every time there is an emissions issue the blame always starts with the DEF. If the ECU is not getting the right reading from the intake diverter wouldn't that cause everything else to go out of spec? My question is how does one re set the Intake diverter?
The shop is booked until Monday so I can't get an answer from them until then#@$%!...... Any thoughts on here?
