Archived MIL Light on with codes set
Archived 99 ram trans issue
Archived 99, 2500 4x4 Auto Stuck in 1st & Reverse
the MIL light stay on this morning when I started my truck to respond to the vol. fire dept call. It has beeen on since then and will not turn off even after several starts and stops. No problems last night hen I parked the truck either
The codes that I have set are:
P0500 No vehicle speed sensor signal
P1693 fault code set
P0251 Injection pump failure feedback circuit
P0253 injection pump fuel valve
P0234 turbo boost limit exceeded
P1693fault code
Are these codes telling me that my Injection pump went south? I have 24 psi from the FASS.
Any advise would be greatly appreciated.
Hey Sarge,
Hope everything went OK on the call.
If it were me I would disconnect the batters for about 15 min. and see if the codes reset.
I have got some that did not make sense and did that.
Sometimes the weather( rain ect ) could cause this.
Maybe someone else can help you with something else.
Good Luck,
whiskey
