MIL on
  • Thread starter Thread starter Casey Balvert
  • Start Date Start Date
AFE Intake System?
Opinion needed on raising fuel rail pressure
C
Casey Balvert
Guest
I changed my oil yesterday and removed the air tube to allow for easier access. I put everything together and started her up to check for leaks. Dummy me. I later remembered I had forgotten to reconnect the plug for the air sensor in the tube. I connected it but now the MIL is lit. P107 and 73 are the codes according to the readout. I presume it was because of the air sensor not being plugged in. I disconnected the battery but it is still lit. Will this clear by itself? She is going to the dealer for the CO2 recall next Monday so I can have them clear it then if it is still on.
Casey
Casey- it may clear after 4-5 restarts, but if it doesn't, not to worry, the C02 reflash will definitely reset everything.....
I yanked the cables yesterday for about 45 minutes while I read the forums. That cleared the code. Thanks guys.
Casey
