Mileage discrepancy 03
Buying A new 2004.5
Up Grade Fog and Backup Lights on Existing Wireing
Well after reading different threads about mileage and seeing that some folks were checking their millage by hand against the overhead, I did also. What I found was a two to three miles difference per gallon. With the overhead usually being the higher.
My Question is, Why is there such a discrepancy and can the computers be programed to be accurate?:rolleyes:
mine usually runs 1 lower than actual hand calcs. No box yet, but thinking the VA is looking better and better.
Well I think it uses some sort of averaging. When I pull trailer it shows high then the next couple of tanks it reads low after pulling trailer then t comes back to within a . 5 mpg after a few tanks of normal driving.
I also reset all the trip computers each time I fill
Milage 03
I also reset mine at each fill up. The last few times the attendant has filled it & even though I tell him to put in as much as possible I don't think he puts in as much as I do.
My overhead computer usually shows a higher reading compared to hand calculations an I reset it each time of fill up. It has been as close to . 2 an as far off as 1. 5. A lot of my driving is two-lane highway to work with red lights an such. An if we take a usually once a week 50 mile round trip to go eat at this certain restaurant, I'll see 16 to 17 mpg when I fill. If not just back an fourth to work an running around town I see around 15 to 15. 5. I have now 16,800+ miles with very little towing.
I mostly reset mine only at fillups, and do the hand calculations. Towing or not, or combination, it is rarely off by more than 0. 1... . I do squeeze in as much as I can every time. .
Very satisfied with the accuracy. .
Mine is usually within . 2 of hand calculating. As of yet, I have nothing in the line of bombs that would throw it off.
Mine used to be spot on. Now it's 2 MPG less than hand calculated. I can't figure that out. Now my truck does have a new ring & pinion. I know almost nothing about differentials. I wonder if a subtle difference in setup on the rear diff can affect the gear ratios and consequently the computer's calculation of fuel economy. Anyone know the answer?
My '99's overhead always showed 2-3 MPG better MPG than actual. After installing the Edge it got worse.
My '03's overhead was pretty accurate when stock. Within about . 5 MPG. With the Edge I'm showing about 3. 5 MPG higher than actual.
I've read about lots of guys having their overheads go crazy too but I checked my mileage for the first time since adding the TST - The over head was high by 1. 9 MPG as usual.
