Tim, try the Fitch Fuel Catalyst. My V6 Maxima routinely gets 32-34 on the hwy now! This, with over 100K on the clock.
AFAIK, it's the ONLY product out there that's not a gimmick. It's also not cheap-- figure $150 or so. Based on my fuel economy increase (from 26-27), I has paid for itself already over the last 30K miles.
I recommend you only install one in a vehicle that you plan on keeping a long time. They last at least 200,000 miles, and have no moving parts.
Installing it in the Maxima took about 10 seconds-- literally. You just drop in these little turds that roll around in the tank and treat the fuel.
I was so impressed, I put one on the CTD. This was a $400 experiment that doesn't look quite as promising. It doesn't seem to be nearly as effective on the diesel as it is on gas. When I upgrade to the max flow line, I will re-do my FFC install, and maybe it will be more effective then. I HAVE noticed lower smoke, and about 1 mpg more overall. But that alone is not worth the $400 for the CTD version:--)
I recommend it VERY much for gassers. I think the jury's still out on the CTD, as I installed it with the DD2s at the same time, so I can't recommend it as strongly, since I don't have an accurate comparison.
The link to more info is
here.
This product also seems to keep the engine a LOT cleaner on the inside. I rarely use an injector cleaner now.
Justin
