My mileage is not that great on this new truck... . I know alot of it has to do with only having 1k on it... . But why would my mileage go down after putting miles on it... . When i started out with 10 miles on it and for the first fill up... All mileage is being hand calculated...
2nd fill: 14. 5 mpg
3rd fill: 14. 2 mpg
4th fill: 11. 8 mpg
5th fill: 10. 8 mpg
Yesterdays fill was: 9. 9
Now all these fills the tank WAS NOT empty... I top off once a week so it doesnt hurt the wallet as bad.....
Any ideas??? THANKS
(This is on dads 6. 7... . Not the truck in the sig below)
Ideas only, no answer:
You say nothing about driving style or loading. Are you becoming more careless or hot-roddish, with increasing familiarity with the rig? Carrying heavier loads, through more traffic, or through hillier country?
The fact that the trend is not irregular, (up-down-up), but increasingly, and steadily "down", indicates, if all your use conditions and fill-level are consistent, that something is wrong, and getting "wronger".
I. e. , if the "trend" continues, you will soon be getting 5mpg. In that case "something wrong" will be undeniable, and most-likely noticeable enough for the service people to find and fix.
Regarding your frequent fill-ups: if you fill a 100 gal tank , but happen to stop short by 1/2 gal, you have effected your "reading" by 1/2%, if at the next fill you top off the tank completely.
If, instead, you put only 10 gals. in, and are short by 1/2 gal,... you have affected your reading by 5% (instead of 1/2%).
Bottom line: If you are after the best accuracy, larger-volume fills will give less % error for any mistakes you make regarding the relative completeness of the fills.
your wallet won't know the difference if the gas money is managed well.
$150(or whatever)/mo. will be the same whether paid in 1 stop or 4. (Your time/trouble investment will be less with 1 stop.
Now that I think about it,... your trouble is obvious :
too-frequent fill-ups.
Since the mileage goes down with every fill, ... the solution is also obvious:
fewer fills!
