Welcome Bud,
I'd have to agree with you; your truck should be able to deliver better fuel milage than that. BUT, consider that most owners (and past TDR mag. articles) have reported that 4wd will cost you 1 mpg, and the extra rubber on the rear axle (3500 - dually) will also cost 1 mpg. Driving 65 - 70 mph puts your motor right in "the zone", which is 1750 rpm to 1900 rpm. You didn't say if your driving was in the mountains or flatter plains, but a steady throttle up the hills lets the turbo do its thing and will improve milage. You won't slow down that much, really. Pushing down the pedal to charge up the hills is a thrill, but it costs extra fuel. Heavy traffic that forces you to speed up and slow down will also cost you some extra mpg's. Some things to check, clean, or replace might be: the screen pre-filter in the fuel warmer, the fuel return valve located on the P-7100 injection pump (if it's clogged or has a weakened spring, too much fuel will be returned to the tank and not enough will stay in the pump to be sent to the injectors. ), thermostat (are you running at optimum temp?), fan clutch (is it only slightly engaged when cold? - Note to Palm Beach FL residents: check this with engine OFF!!) Hope this helps. I'm consistantly getting 20-21 mpg with a 50-50 mix of suburban driving with short highway runs. Just got back from a 600 mile trip into the mountains, but the schedule kept me running faster than I usually go. The milage reflected that: 20. 5 mpg. On a 70 mph ave. trip 5 months ago the truck gave me 22. 5 mpg. Previous best was 23 mpg. But mine is 2wd and a 2500 model.
95 2500 SLT, clubcab, 2wd, longbed, a/t, 3. 54, 138K miles, "all the usual refinements"
