Engine/Transmission (1994 - 1998) mileage woes!!serious ones
Engine/Transmission (1994 - 1998) high rpm popping
2nd Gen Non-Engine/Transmission Ham Radio in Center Console
mileage has dropped to about ten so i swapped aout turbos back to the stocker but it isn't better. i'm producing alot of power but even when i stay out of it i have the same result
97 4x4
370's
hx35 @43 lbs max
4gsk
191 dv's
also i'm not getting the spoolup i'm used to and am not achieving normal boost levels at wot
any ideas?
I-6DZL said:
Sounds like a boost leak or possibly low fuel pressure. Check the clamps around each boot.
He's on the right track... ... I say its a bad boot somewhere.
Start the truck and check to see if any of the boots are swollen up like a ballon, or have indentions (like dimples) in them. If one of them is then it needs to be replaced.
I'd almost bet $$ its the passenger side boot @ the intercooler. Mileage took a crap on me HARD on my last truck and couldn't figure it out until I got up on a dyno and someone saw the boost leak from below. Had the current truck not even 4 months and mileage took a dump on me again. both times it was 3-4mpg. Both times I replaced the boot mentioned above and the mileage came back.
