Originally posted by mcoleman
... ... Plus they are made in the USA. [/B]
next time I need to drill concrete I will go buy the Bosch as I was recommended to in the first place, I have used a Bosch since and like it a lot, it actually will drill concrete without putting all my weight on top of it.....
Originally posted by HVAC
Not sure what SDS stands for, however it is a specialized system with special bits. You don't use a chuck, the bits lock in and are often hex shafted or splined. Things get very expensive. This is like a cross between your drill and a demo tool.
HVAC said:I like my red tools a lot. Nuthin' like pulling out a tool you can rely on when there is work to be done. Starting with 12v cordless drills I've purchased a number of Milwaukee stuff. Haven't found anything that wiil stop my "Supersawzall", not even a "02 Ram![]()
Hohn said:I can't believe how powerful this drill is!! It has an 8. 0 Amp motor that stops for no man.
It's almost useless as a screwdriver, since even if you blip the trigger it will still strip out whatever you are driving. it takes a while to spin down.
It's also very lightweight. i can use it with one hand, as if it were a light 3/8" rechargeable. I wouldn't recommend going one-handed if you are drilling something that might bite you-- this thing will twist your wrist something bad if you aren't careful.
I got the one with the grip-lock chuck. It's keyless and stout.
I like this drill so much, I might soon be looking at other Milwaukee power tools-- they seem to be very strong, well-made tools.
Now I just need to get that Orbital Super Sawzall--- (11 Amp motor!)
HOHN
