I have a 99 CTD with the overhead minicomputer. Recently needed to re-set the compass and subsequently the temperature readout is wildly inaccurate usually in the + 200-350 range. I suspect the compass change is unrelated to the temp. problem, but the timing is peculiar.
I did a search and found a threat that included the following paraphrased remarks.
"I would take it to the dealer and have them look at it. It might be a simple fix - like a thermocouple"
"This is part of the manual description:
AMBIENT TEMPERATURE SENSOR
The temperature function is supported by the ambient temperature sensor, a wiring circuit, and Front Control Module (FCM). If any portion of the ambient temperature sensor circuit fails or if Programmable Communications Interface (PCI) Data Bus information is missing, a (- - ) will appear in the display in place of the temperature. When the sensor is exposed to temperatures above 55 C (130 F), or if the sensor circuit is shorted, 55 C (130 F) will appear in the display in place of the temperature, when the sensor is exposed to temperatures below - 40 C (- 40 F) or if the sensor circuit is open, - 40 C (- 40 F) will appear in the display. "
I suspect the sensor/thermocouple. Anybody know the location or have other information regarding the problem?
TIA
Jim
TIA
Jim
