Mirror Lack of Movement
Horrendous Smell from engine bay.
Bolt torque values
RMHanes
The driver's side mirror just recently will not move in or out. It will move up and down and the passenger side moves both up / down and in / out. Any hints or suggestions as to where to start looking for the problem? Truck is a '98.5 with about 200,000 miles.
I think it would be very limited as to what is wrong - a switch problem, a mirror motor problem, or wiring inside the door problem. Likely the mirror or the switch.
When you do the "in and out " function, can you hear the motor working? If you can, then you probably have a mechanical issue in the mirror housing.
- John
Try moving the mirror up and down a few times with your hand, sometimes that will free it up. Also I believe if you push the mirror all the way down you can squirt some spray lube under the rubber boot"?" bg
Mine did that and I moved by hand and there was a dirt dobber nest muddled up behind it, power washed it and works great now
