Can you pass some more info as to where you got those fogs in the grill from?
I'm still in the process of getting all my electrical stuff done... stereo, gauges, lights, etc. , so what you see is not quite the completed version yet.
The lights between the grill and the bumper are (like the mirror lights) from JC Whitney.
The clear ones are driving lights, and the ambers are fog lights. As I recall, to fit 4 lights in this location, they should each be about 2" high and 6" wide.
http://www.jcwhitney.com/autoparts/...03728/p-2003728/N-111+10201+600010204/c-10101
I made a bracket out of 1/4" thick aluminum to mount the lights to. It attaches to the 2 inner bolts of the tow hooks on each side. At the ends, it is about 3 1/2" wide, but necks down to about 1 1/4" behind to lights to minimize the amount of air that is blocked from reaching the intercooler, radiator, etc.
I used 3/8" stainless steel tubing and bent some "light gaurds" to conceal the lights somewhat, and to integrate the look a little with the factory grill. I placed the tubing at the very top and bottom of the lights so they didn't interfere with the light output.
I don't actually have these wired up yet, so I can't comment on light output. I just installed a separate Painless fuse block, and will use this, along with some relays, to power the lights. These are Halogen H3 55-watt lights, and will help visibility alot, but if you had the money, PIAA makes a light about this same size that would probably offer much better ouput. Maybe I'll switch over someday... still a work in progress! --Eric
