mirrors
installing aux fuel tank?
Wierd Voltage Issue
I have a 03 Laramie with the heated mirrors. I like these mirrors, but when I tow big trailers I can't see a thing! What are my options? I would like to keep the heated set up, but I don't want the strap on mirrors that are out there. Do any of the newer trucks have the heated tow mirrors? Will 04, 05, 06 mirrors fit my 03? Thanks for the help.
Am I right that you have the heated but non-tow mirrors? If so, I think at least through '05 they're the same [not sure if they changed in '06].
Ryan
they are around 350 from the dealer are heated and power easy to install you dont even need to remove the door panel just carefully pull it back on the corner and remove the one nut behind it first then take the other two out that are outsied of the door panel.
Hey, I have left and right from my '03, the towing miiors. Left side has damage, but both are functional. Cost, $150 for both, you pay shipping.
Eric - '03 SRW SWB QC WHITE 3:73 4X4 Limited SLT 6SPD a GREATE TRUCK!
