Mishimoto radiator
Need Gen1 Gauge Mounts
Jammed or sticky shifter 93 Dodge W250
Who knows if the cooling system mainly the heater core is up to the task of the 19lbs radiator cap that comes with this mishimoto radiator ?
I wounder if anyone who has used this radiator, has had any problems with using the 19lbs cap that comes with the radiator (blown out heater core)
I have 470k on this 1st gen and the R-12 refrigerant still blows cold
Don't want to damage the heater core
System has never had any rust in the coolant.
To whoever can help..
I think you would be fine the stock gen 1 cap is around 16 lbs , you could just put a stock poundage cap if you like ,really all the cap pressure does is changes your boiling point
