Miss in hard pull with DD UFM any advice?
bed rail tool box options
"MAKING" a dealer honor warranty...
Kent Kuykendall
Just towed with my new DD UFM and DD 2's. It misses or bucks in a hard pull mostly at around 22-26. Truck did not do this with my dad's DD TTFM. Any Ideas? Could it be the pump wire connection? I checked it at the schotch lock and it seems tight.
Thanks for any help
Kent
Injectors and new tubes have been in for a year with no problems. I have a Fuel pressure gauge with two sending units with no fuel pressure problem before or after filter.
Kent
Check the pump wire again
Kent,
My truck had a rough idle after I installed my Comp. Checked the pump wire connection and reinstalled it with a better scotchlok and the problem went away. Down side is that I have a more noticeable nick in my pump wire:(
Hope this helps,
Eric
I Put a regular scotch lock on the wire instead of the T style that came with the Box and it seems to be better now. I may just solder a conection at the wire and then I will know that it is not a conection. Has anyone done this?
Kent
I thought that it was better but after driving it again it sometimes misses. :confused: I read the thread, maybe I will solder the thing. Sure seems as though the schotch lock it tight though. I'll call DD tomorow and ask them before I solder it.
Kent
Kent, I was having various problems with the initial installation of my Banks system. Missing, intermittent power, check engine light, etc. Soldering fixed it, no problems since.
Tom
