Do you have a CEL?
The lift pump pressure is a little excessive. It's always a good idea to verify pressure with a manual gauge, then figure out why your lift pump is putting out excessive pressure. I'm going by memory but I believe the DDRP pumps have a spring and ball to regulate return flow to the tank. Could also be the overflow valve on the VP, but generally they fail the opposite way.
