Engine/Transmission (1994 - 1998) missing kdp
Engine/Transmission (1998.5 - 2002) Rear diff service
BBFields
I was doing my tst kdp repair and when i got the gear case cover off the pin was gone. I cant see any damage, and cant find the pin. Is there any baffles in the oil pan that would stop it from falling to the bottom of the oil pan? Or is there someplace else i should be looking ?
If it is not in the gears it is the pan. Don't worry about it but put a new one in (from Cummins) and make sure the gear case bolts are tight.
Go buy a lottery ticket! You might be able to fish it out with a magnet on a stick but it will be OK rolling aorund in there. Next oil change you could try to drag it to the drain hole with a strong magnet on the outside of the pan.
