ok here goes, tonight I changed the filter and installed an oil pan drain plug kit (could have chosen a better place in the pan) reinsalled the pan put 5 quarts of fluid in the pan and ran out of time to finsh the fluid change per LBrock susgestions in a serch i found were he says to remove the cooling return line from the trans and start the engine for about 20 seconds and recheck the fluid level then repete till new fluid comes out ..... heres the ? will the torque converter back drain and contaminate the new fluid i have allready put back in the pan or am i ok to finish in the morning?
thanks in advance !
Guy
thanks in advance !
Guy
