we own a mitsubishi fm-mr straight truck with a six speed manual transmission, since we have owned the truck it has shifted poorly, we have broken two linkages to the transmission because it is so diffucult to shift. recently the clutch went out and we had a new clutch installed -- still shifts like hell. It seems to shift fine for the first 20 minutes or so then once it warms up it grinds into gear and can be hard to even get into gear -- the clutch is not out of adjustment -- Our mechanic has checked the slave cylinder and it is ok - he said they either work or don't work and there is no in between -- he thinks there is a linkage problem but I disagree since it shifts fine when cold -- any advice would be appreciated -- Darren
