MITUSA pump system
FASS/AirDog install: Fuel return lines?!?!?! 3rd gen
Pacbrake Problem
I saw Opies pump system on a 12 and 24 valve and a duramax. Is comperable in price to the fass or airdog. 550-600 range I believe is what he told me.
Opies pump is very very similar to the RASP and works exactly the same way. The plumbing is a bit different but other than that it is a RASP made by someone else.
From the outside, and I'm a novice at this, the RASP has seals on the front of the pump drive shaft. The MITUSA frame seems to come all the way to the front of the casting. Does the MITUSA have seals?, need seals?
Bob Weis
