Mixing Synthetic ATF and Conventional ATF 4+?
aftermarket auto trans cooler for maximum heat control
Noob water/meth questions
:confused: I'm going to install a deep pan and new filter this week. After I Drain all that I can, I want to add synthetic to the remaining conventinal ATF. Is this okay?Anybody know. Thanks.
Should not be a problem. Read the label, it should tell you. I switched mine over at 40,000 miles, drained the transmission and filled up with Amsoil, and now change mine out about every 25,000.
