Moderators************
How do I change a thread title?
High Speep ISP Users!!
Oo. To The Moderators of this Fine Website,
I would like to openly thank the Moderators of this website. Thanks Guys!! I like the new speedy process it is to zip thru all the pages on the Threads now. Instead of before when you scroll thru afew at a time, now we can zip right thru them with ease. !!!:)
Keep up the excellent job fellas!!
RacinDuallie:D
Luke Warmwater said:
Perfect unless you're on dialup and now you have to wait for hours while the dang thing loads all the posts and even worse, all the images!
Go to your use control panel and edit the user options.
You will be able to set how many posts per page there. I have it set for just 10 when I get home and 40 when I am at work.
Very cool option.
That was my mistake. I put up a view all option and changed the max setting for the forums so that would work - problem is that the max setting is also the default for everyone unless they've selected one (I now know). I didn't realize that because I had mine set for 40. I've changed it back to the default of 15 until I figured out where to change the code to make the view all option work.
All fixed now. The default is now back to 15 unless you've chosen another option in your user control panel under options. If you want to view ALL of the replies on one page pull down the thread tools menu to show all posts on one page.
