Fits 1994 to 2005 Dodge Ram Cummins Turbo Diesel.
Just Factory Rebuilt and tested and still in factory sealed packaging with gaskets.
reason for rebuild, Airbox too restrictive and damaged the oil seal. Last picture is another one installed on a 2000 Dodge Cummins.
Great turbo for towing and power upgrades,
Need to have a high flow cold airbox system like Volant and a 4 inch exhaust.
Factory Specs.
Updated and modified Borg Warner K27 replacement for the Holset HX35W turbocharger.
The K27 is capable of supporting up to 400HP. It features a 60/83.7mm Forged Milled Wheel (FMW) 7/7-blade design compressor to resist low- and high-cycle fatigue. The turbine is a quick-response, 70/58.83mm 12 blade advanced design cast in Inconel and provides great backpressure control.
The turbine housing is a twin-volute, single-valve wastegate housing with 18.2cm2 nozzle area and an adjustable wastegate actuator that is preset at 1.8bar. The oil Inlet is threaded M12 and the oil drain is threaded M8, just like the Holset.
$699
call 352-270-5176, ready to ship in original box
Factory Specs.
$699
