Hi KC,
New pumps are warranted by Bosch. If the pump is not "altered" then Bosch will stand behind those pumps, but, if the pump is altered in any significant way then the vendor cannot return the pump to Bosch for warranty due to those alterations.
Normally when we start to tinker with these things we assume the liability/reponsibility for the potential results such as early failure or breakage.
It's the cost of "playing" I guess you could say... .
You can ususally expect to have good results from a pump if you chose to tweak it, or, have it tweaked by a shop prior to shipment.
The "usual" mods are being run/used in most of the pumps we are running on our trucks today/here... .
Those mods are things that you can usually find here on the site and do yourself if you choose. Personally I like the idea of doing most of those things myself because it helps in the learning/understanding of how they operate and what the results are of a mod I have done myself.
As far as I know there are no "Kits" available for rebuilding because they process requires putting the pump on a stand and going thru a significant number of checks and tests (I have seen the amount of testing) to confirm that the rebuild is "within spec" for the pump. This makes it pretty hard/almost impossible for the average owner to do the rebuild personally.
Taking all that into account you can expect to have a good pump on which to base your mods if you start with a new pump... . again, you'll go into that knowing at the outset that you are pretty much voiding any mfg warranty when you start the mods.
pb... .
