I just bought my first Dodge Ram with a cummins last Wednesday. Well I decided to do a full service on it, (oil change, transmission service, fuel filter, BHAF). Well I got to reading about checking the fuel pressure so I hooked up my Snap-On gauge to the test port on the fuel filter canister and it showed ZERO. So I removed the valve from the port and reinstalled the gauge thinking it wasn't getting a good reading, the truck fired up gauge showed zero, then the truck shut off after about 10 seconds and wouldn't start back.
Yeah, you guessed it, the lift pump went out and wouldn't push the air out that I let in when I took the valve out.
So anyways, I've just installed a brand new Carter lift pump (had to to get the truck running quickly). What can I do to prolong the lift of this thing? I've already got a cab mounted fuel pressure gauge setup on the way, but what else do I need?
