Moisture in Injector Plugs
Fuel Filter replacement
engine codes
I installed the Powermax awhile back and when I got a code for the bank one injector I pulled to check all the connectors and noticed there was moisture inside the connector. :--) I checked all of them and they all were a little damp. I decided to put Dielectric grease on all the plugs. So we will see. :rolleyes:
Some of you that are getting codes every once in a while for your inj might want to check this out. And everyone else should check anyway.
I've had mine disconnected 3 or 4 times with no moisture noted. I do occasionally wash down my engine. I live in an arid region if that makes any difference.
Vaughn
